Rakennussarjaa
ärrä
Rakennussarjaa
Viesti Kirjoittaja ärrä »
Jos et vielä ole twin cam konetta kasannut, niin tällä vois alottaa
tilata voit täältä
Re: Rakennussarjaa
Laitetaan kuva näkyviin...
Assemble a 1:2 Scale Harley-Davidson® Twin Cam 88® Engine with this
Visible Plastic Model Kit from Testors.
Suitable for Ages 12 & Older.
FEATURES: Build a beautiful, exacting replica of the larger and more
powerful Big Twin engine with more than 150 precisely engraved,
injection molded parts.
Clear external parts allow a clear view of all key internal parts. The mechanical operation of the real engine is demonstrated with
working crankshaft, pistons, valves, rods, rocker arms, and
camshafts.
An electric drive motor is concealed under the attractive display
base, and has a sound card recording of the real H-D® Twin Cam 88®.
Complementing chrome plated parts also included.
Metal coil springs and vinyl belts.
Detailed assembly guide with illustrations.
INCLUDES: (1) Engine Model
REQUIRES: Assembly
Cement (HCAR3415)
CA Glue (GPMR6001)
Hobby Knife (HCAR0100)
Phillips Screwdriver
(3) AA Batteries (SANP3501)
SPECS: Scale: 1:2
Overall Height: 10.5" (267mm) - w/o base
Parts: 150+
Skill Level: Experienced/Difficult
COMMENTS: May be painted if visible features are not desired.
Other engine kits also available:
- 1:6 Scale Dodge 426 HEMI® -- Metal
- 1:4 Scale Dodge 426 HEMI® -- Visible Plastic
- 1:4 Scale Dodge 426 HEMI® A990 Race Engine -- Visible
- 1:6 Scale Dodge A-990 HEMI® Race Engine -- Metal
- 1:6 Scale Chevy® Small Block -- Metal
- 1:4 Scale Harley-Davidson® Twin Cam 88® (TESS0457) -- Metal
- 1:6 Scale HEMI Street Engine -- Plastic
kr6/5/06
ir/kh
- If you need more information, use these Testors resources - Web Site: http://www.testors.com/" onclick="window.open(this.href);return false;
Phone: 800-435-2942
Postal Address:
Testors
PO BOX 73863
CLEVELAND, OH 44193
Ja laitetaan vielä hintakin esille:
Retail Price
109.99 $
Tower's Low Price
82.99 $
Ja läpinäkyvillä osilla joten sisäkalut ja toiminta näkyy.
Vähän rupes kiinnostaan...
edit:
kumma juttu toi kuva kun välillä näkyi ja sitten taas ei 8O
Viimeksi muokannut smuige, 13:52 01.02.2009.. Yhteensä muokattu 1 kertaa.
Oz
Re: Rakennussarjaa
Viesti Kirjoittaja Oz »
Kolmas kuva yritys:
Mielenkiintoinen. Olis hieno kirjahyllyssä. Meni kyllä hankinta harkintaan, jos joskus sais ihan oikeankin. :D
Viimeksi muokannut -Harikka-, 08:38 28.05.2019.. Yhteensä muokattu 1 kertaa.
Oz
Re: Rakennussarjaa
No pitihän se tilata. :D Ebaystä 91$ postikuluineen. Pääsee valmistuttuaan kirjahyllyssä kunniapaikalle.
Oz
Re: Rakennussarjaa
Kuva <-klikkaa suuremmaksi
Noin!
Siellä se nyt on. Ohjeissa oli joitain virheitä osanumeroissa ja kerran käskivät enskakopan jo liimata ja sen jälkeen olisi pitänyt laittaa yksi ruuvi sen taakse. Ihan ok ohje muuten. MUTTA, kuminauhavedon vuoksi nokilla ei ole mitään rääpyä ajoituksesta ja nokat ei ole nokat vaan pyöreät, ymmärrettävää sinänsä, koska sitten ei tule niin suurta liikettä vastustavaa vääntöä. Ja suurin virhe, kone pyörii väärin päin! Tekniikkarakkaana en voinut jättää sitä ensiseisomalta niin, johdot poikki ja toisinpäin, mutta sitten se ei jaksanutkaan enää pyörittää koko konetta. Liekö sähkömoottorin kulmavaihteen hammaspyörät sitten sellaiset.
Ei vaan meinaa jaksaa pyöriä ja kitisee ärsyttävästi, koristeena katselee. Ei kannata esitellä liikettä kellekään joka vähääkään moottoreista ymmärtää. :)
Kertaallensa jumittui liimaillessa, yhdestä hihnapyörästä valui vissiin vähän liimaa "runkolaakerin" väliin ja siihen jökkäsi! Akan varastoilta kynsilakanpoisoainetta loiskisloiskis sinne väliin ja pihdeillä puoliväkisin eesuntaa. Sitten lähti pyörimään helposti ja kohta jökkäsi taas, sama operaatio, sama tulos. Sitten hain juuri hankkimani pienen sähkövingun, sain patentoitua sen tuon lelun akseliin kiinni. Uusi loraus kynsilakanpoistoainetta ja muovikoneelle rinkiä niin että varmaan riitti! :D Pyöritin niin kauan että vingun hiilistä alkoi savu nousta. Ei jumittanut enää sen koommin liimat... :lol:
Re: Rakennussarjaa
Jos kerran nuo muovi osat "tökkii" niin voihan noi osat viilailla aikansa kuluksi vaikka alumiinista, aikaa saattaa vähän vierähtää :lol:
hdjokke
Re: Rakennussarjaa
Viesti Kirjoittaja hdjokke »
Sepixlh kirjoitti:Jos kerran nuo muovi osat "tökkii" niin voihan noi osat viilailla aikansa kuluksi vaikka alumiinista, aikaa saattaa vähän vierähtää :lol:
Tosimies ostaa oikean koneen hyllyyn koristeeksi.
http://www.harley-davidson.com/pr/eng/e ... cale=en_US" onclick="window.open(this.href);return false;
Siinä ainakin on kaikki osat tallella. Niin, ja voihan koneen ostaa osa kerrallaan vaikka Chicagosta, jos rakennussarjan haluaa.
Oz
Re: Rakennussarjaa
hdjokke kirjoitti:Tosimies ostaa oikean koneen hyllyyn koristeeksi.
Ei saanut ihan 90:llä ja saattaisi tuo hyllykin notkahtaa vähän nykyistä enemmän... :D
SenioRR
Re: Rakennussarjaa
Viesti Kirjoittaja SenioRR »
Tää ei liity Harrikoitten myllyihin, mutta pienoismalleihin kyllä.
Tämän tekemiseen tarvitaan jo vakaata kättä ja annos jos toinenkin hermoja... http://www.youtube.com/watch?v=6AQFRWgW9bk" onclick="window.open(this.href);return false;
H-D Softail Custom 1998
Re: Rakennussarjaa
Oz kirjoitti:Kuva <-klikkaa suuremmaksi
Noin!
Pistämpä tännekin, oli puhetta tuolla toisessa ketjussa. Samoja murheita olet näköjään huomannut.
UrpoTJ kirjoitti: Juu toinen tuli minulle, kiitos vaan Harikka. Kiitos myös herra S:lle tiedoista koskien puuttuvia osia. Sarjasta puutui yksi pussi osia: jouset, hihnat, nokka-akselien support plate, joka olisi pitänyt tehdä joka tapauksessa uusiksi muutoksista johtuen!
Malli pyöri väärin päin (näyttivät pyörivän näin muutkin Youtubessa). Muutin moottorin johdotusta, nyt pyörii oikein, mutta tahmaisesti.
Ikävämpi juttu on, että mallissa nokka-akselit pyörivät tuplanopeudella kampiakseliin nähden. Piti siis rakentaa toinen nokkaketju. Nyt pyörivät oikealla nopeudella mutta eivät kyllä pysy venttiilit oikeassa ajoituksessa!
Vielä pitäisi löytää sopivat venttiilijouset, keinuvivut eivät oikein liiku kunnolla.
Lisäksi pitää löytää sopiva voitelu muoville, monenlaista on kokeiltu, ei käy moottoriöljy, CRC, aseöljy, akkuvaseliini on ollut tähän mennessä paras mutta silti kitisee ja kanittaa...
Metallista tehty moottori on siitä mukavampi, että osat voi purkaakin jos huomaa tehneensä väärin.
Ohessa videolinkki aiheesta:
http://www.youtube.com/watch?v=vXYoL69H ... e=youtu.be" onclick="window.open(this.href);return false;
Re: Rakennussarjaa
Hmm, pitäisköhä sitä kasata yks rautiksen mylly tohon pönttömuurin päälle, kukakoha sen nostais sinne :D ne tahtoo painaa jonkunverran :lol:
Vois olla muutamat lohkot jo semmosessa kunnossa että sopis siihe hommaan 8)
ma^ko
Re: Rakennussarjaa
Viesti Kirjoittaja ma^ko »
Harikka kirjoitti:Mie oon nähny Amerikassa asuessa kaks Evo-moottorin näköiskopioo lasipöyän jalkoina, oli aika vaikuuttavan näköne tutun olohuoneessa :wink:
Yhdel tutulla on/oli olohuoneessa kaiutin jalustoina knuckle ja early-shovel koneet ja lasipöydän alustana Chevy SB alukansilla ja suunnitteli 4/71 tai 6/71 pumppua sen SB:n päälle. Perusteli sillä että pitää kolme maailman kauneinta moottoria olla kotona. Early oli ainakin ihan täyskuntoinen, peruskorjattu kone, SB oli "sisustusobjekti", knucklesta en tiedä oliko toimintakuntoinen. En ole kyläillyt hänen luonaan nyt yli kymmeneen vuoteen joten en tiedä onko vermeet sil edelleen himassa.
Re: Rakennussarjaa
Tuossa heppu on rakennellut mm. kellonosista pienoismotskareita
http://www.pfau.com.br/artepfau/index.php" onclick="window.open(this.href);return false;
Rakennustarpeet siis ihan mistä vaan.
Isommassa mittakaavassa noita on taiteillut mm. Tykkyläinen.
